8 | |
6 | |
4 | |
3 | |
2 |
basically the idea is to enable the step into feature that you have if you drop an accessor VI for a custom LVOOP class on the BD also available when you use the accessor VI by wiring a LVOOP class to a property node. At the moment you can only "step over" the property node (even when clicking on the "step into" button) which is really annoying for debugging purposes (when the code is misbehaving inside the property node).
This idea is related to the idea mentioned here (which would probably also lead to solving the issue in the process of being implemented):
Since AQ proposed to post this as a separate idea (and not very much has happened in the other thread since then) I did.
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
