| User | Kudos |
| 5 | |
| 3 | |
| 2 | |
| 2 | |
| 2 |
When activating quickdrop it should remember the previous search results. Many times you want to successively place related items such as when using a library.
Initially it activates with the search field empty. Type a few letters and a filtered list shows.
On the next activation the previous search results should be the same. This allows you to double click a filtered item or immediately start a new search.
