Labview implements lots of functionality in the right click menu, resulting in large and deep menu hierarchies. Often I want to select multiple items, but the context menu disappears after a single selection requiring me to go back to the original item and renavigate the menu tree. That's a lot of repetitive, fairly precise mousing.
I'd like to have a hot key that prevents the context menu from disappearing after I select an item. For example, if I held down the Ctl key while deselecting "Label," I could immediately move down to "Caption" and select it, making the whole process much easier.
Any idea that has received less than 9 kudos within 9 years after posting will be automatically declined.
