| User | Kudos |
| 18 | |
| 6 | |
| 5 | |
| 4 | |
| 2 |
I like quick drop shortcuts, and I would use them even more often if they could sync between computers that I work on. I'd like to see an option to specify the location of my quick drop shortcut options. Then I could store them in a folder that would stay in sync across multiple machines, ie my dropbox folder.
Thanks!
