5 | |
2 | |
2 | |
1 | |
1 |
How about adding two error connectors at the left and right bottom corners for some nodes such as those in the time pallet (e.g., "wait until next ms multiple" so that the user can have more control on when these nodes are executed?
This surely will reduce the use of sequence structures (which is one of my favorites but I have been told not to use if possible) and make the BD a bit cleaner too.
