Today, when you create a case structure and wire a string to it, the case structure becomes case sensitive. This may have been relevant in the 1970s, when every bit was important, but these days I'm guessing that in at least 95% of the cases the structure should be case insensitive, although most people are probably not even aware that you can change it.
So, why not make the structure default to being case insensitive instead of case sensitive?
Actually, I would possibly even suggest removing the case sensitive option altogether, but this is probably required for some things and would break existing code which relies on this.
