| User | Kudos |
| 11 | |
| 10 | |
| 7 | |
| 5 | |
| 4 |
I hope it would help.
When create a subvi, can easy to do with press shortcut key such as Ctrl+Shift+V, instead of struggling to select from edit list.
Similar from these snaps,
This is already possible by either:
1. Launching the edit menu with Alt-E then pressing the 'S' key for Create SubVI, or
2. Setting a custom keyboard shortcut for Create SubVI in Tools > Options > Menu Shortcuts.
