8 | |
6 | |
4 | |
3 | |
2 |
Currently if a VI is set to subroutine priority you can only call subVIs within that which are also subroutine priority (to prevent priority inversion I guess).
It would be great if it was possible to also use inlined subVIs inside subroutine VIs.
As inlining basically defeats a VI's priority setting an inlined subVI would just "inherit" the subroutine priority of its caller. I configure many of my very small reuse VIs as inlined (most of those in the GPower Error & Warning toolset from v2.1 onwards for instance), since they typically perform much better than subroutine that way. But since they are configured as inlined, this effectively prevents them from being (re)used inside subroutine VIs.
Cheers,
Steen
