Chetan_G
Support basic math operations in numeric controls
I come across many situations where the value that needs to be entered into a numeric control is not readily available but has to be computed (For example: I need to enter the value 679.5/23.2 into the numeric control), then I would need the help of a calculator to compute this division answer, copy and past it back in the LabVIEW control.
So it would be good if we support basic math operations (+-*/^%) in the numeric control (and constants?) so that even if I enter 679.5/23.2 or 2^23 or 172857+3675 in the numeric control, it evaluates the math expression in edit time and assigns the value to the control. This would less than 5% of the time it takes currently in LabVIEW.
(One other option would be to change the code to accept 2 controls and use the division primitive. But this may not be feasible if the VI is built into an application or if the operation is a one time calculation that need not be repeated, or if the math operation that is done to calculate the input to the numeric is different each time,etc)
11 Comments
JordanG
NI Employee (retired)
