13 | |
8 | |
3 | |
3 | |
3 |
Firefox is not publishing the PNG data that contains a snippet inside the Drag and Drop info, however the info is stored inside CFSTR_FILEDESCRIPTOR (source) it would be very helpfull if LabVIEW supported this as well.
TOn
