6 | |
2 | |
2 | |
2 | |
1 |
It is 2011, and everyone is either making the transition to 64bit, or have already done so. Yet LabView on Linux is still stuck in 32bit, and this means that for modern Linux installations you have to install a ton of 32bit support libraries just to run LabView. Not to mention missing out on all the 64bit fun that everyone else enjoys these days, such as access to more memory. Please do something about this.
Available with LabVIEW 2014 and later
