It would be beneficial to have the ability to specify what delimiters you can use with the Build Path function and other File I/O functions in LabVIEW. Other countries sometimes use characters other than the backslash "\" as delimiters. For example, in Japan, the yen symbol "¥" is sometimes used. (See attachment for a specific example.)
Some LabVIEW functions, such as Spreadsheet String To Array, already have the functionality to specify delimiters. It would be great for versatility if this could be provided for all File I/O functions.
