6 | |
2 | |
2 | |
2 | |
1 |
Description of the problem :
If we build a project using Classes (or Xcontrol), we must be careful when we names the subVI of a class (or Xcrontol), and take care of NOT using character such as "é", "ç" or special character in the names of the VI. If a sub-VI of a class, or of a Xcontrol, a class itself, or a Xcontrol itself, have a names using one of this character, we can build the project, but the .exe will not run on some computer (such as Chinese, Russian etc) .
The problem is only for names relative to class or Xcontrol. I never had trouble with other VI. And is a shame because when we create a Xcontrol, a class, A class property, etc... Labview automatically suggest nice name like "façade blabla", "écriture blabla".
So I suggest :
- Solution 1 (it will be the best) to allow localized names in class and Xconrtol, and when a project is build, the .exe will run everywhere on the planet.
- Solution 2, don't allow these names or at least warn us when create these VI, and also DON'T automatically suggest names that will cause trouble !!!!!!!
Any idea that has received less than 7 kudos within 7 years after posting will be automatically declined.
