6 | |
6 | |
3 | |
2 | |
2 |
Sometimes, like in many other software that have a paint feature, we need color swapping between foreground and background. The idea is to add a spot in the Tools Palette to allow this operation in one click. Here is a suggestion:
It's difficult to see the spot because I did not changed anything, just added the double ended arrow. One way to help the visibility is turn it white when the mouse hover over it.
