11 | |
11 | |
3 | |
3 | |
2 |
I want to swap sides for the scale on my Front Panel Tanks and DSC vessels like Pressurized Tank.
This is very easy to do with a Waveform Chart or Graph but impossible with Tanks and Vessels unless you wire up some property node scheme to change the position of the scale, but then the indicator numbers are now between the vessel and the tick markers, making it a look a bit unnatural.
This would be very handy, especially for DSC processes where I'm trying to mimic process flow on the Front Panel and pipes could enter tanks from different sides.
