| User | Kudos |
| 4 | |
| 3 | |
| 3 | |
| 3 | |
| 2 |
Hi All,
I had posted this same idea in another post but it didn't have enough clarity and was mostly misleading the forum members. I was not able to edit it that I had to post this in a new thread here.
The Idea
I felt that it would be good to have an option to switch to the last visited case in a case structure with numerous cases when going through the cases for debugging or understanding a code. It often happens that I have to scroll through the list of cases to get to a case and then may be I'll have to check something in the top most case. Again if I have to check the last visited case, I have to again scroll all the way down to the case, which becomes a little tedious. Instead, it would have been good if we had some kind of option to switch to the last visited cases sequentially (in a right click menu of the case structure or some keyboard shortcut after selecting the case structure).
I'm sorry if someone has already posted this in the idea exchange forum. I tried to search it but couldn't find any such posts.
Nitz
