| User | Kudos |
| 18 | |
| 6 | |
| 5 | |
| 4 | |
| 2 |
As already mentioned here long ago, there is a need for system containers.
Most of my front panel uses system controls/indicators and I often use arrays and clusters. The currently available containers (modern, classic) simply don't match the overall system style.
The system palette needs a "System Array, Matrix & Cluster" sub palette.
A quote from my old comment says it all:
For example, there is no "system" array container (with a correctly colored frame and a system spin control as index control) or "system" cluster container (could look similar to the system radio button control).
