When changing a System Control enumeration to an indicator, the drop down arrow should be hidden/removed and the indicator should look like Enum 3 above instead of Enum 2.
In many of my UIs I will use a typedef enumeration as a control for the user and also an indicator to show status back. The arrow being shown in an indicator is confusing.
