11 | |
8 | |
3 | |
3 | |
2 |
LabVIEW comes with a example (Check TDMS File for Fragmentation.vi) to check is a TDMS file is fragmented:Check TDMS File for Fragmentation.vi Block Diagram
I create a subVI based in this example and added to my personal library. How about having a "TDMS is Fragmented" as a native function in the "TDMS Streaming" palette?
This is a proposal to the VI's icon:
