By using the property node "Allow Multiple Rows" of Tab Control, this allows to arrange any tab extended beyond the width of the Tab Control, but there is no property node to inform the quantity of rows that were added.
It would be interesting to have this property node because it would be possible to perfectly fit the dimensions of the Tab Control when it is resized.
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
