| User | Kudos |
| 11 | |
| 10 | |
| 7 | |
| 5 | |
| 4 |
Currently, when you have multiple LabVIEW VIs or projects open, there are individual windows associated with each. (2 for each VI) This can quickly get out of hand. I would like to see a Tab View implemented similar to internet browsers. Thus, each LabVIEW session (i.e. each VI or project currently open) would be represented by a single tab within one "master" LabVIEW window. When you click on a particular tab, the block diagram (or front panel, depending on which one you last viewed) is displayed for that particular VI. Each project would have its own tab as well. This feature should help users to better manage multiple open VIs and projects.
