3 | |
3 | |
2 | |
2 | |
2 |
If my fingers have to leave the home row while using Quick Drop, a lot of the speed benefit of that feature is lost. When coding in LVOOP, I find that I often have to manually select the instance of a dynamic dispatch VI from a list of identically named instances. Right now, I have to use the mouse or the arrow keys to navigate the results list. Why not tab and shift-tab through them instead, allowing my hands to stay in place so I can use the appropriate keystroke (CTRL+I or CTRL+P, etc.) after selecting the method I want?
