Petru_Tarabuta
Tabbing between front panel elements should be possible at Edit Time
Status: New
Suppose a front panel contains the three elements seen below, with the first one being selected.
In the situation above currently pressing Tab does nothing. It would be useful if, instead, pressing Tab would cycle the element selection to the next element in the tabbing order, as seen below.
If Tab was pressed again, it would cycle to the next element in the tabbing order, as seen below. And so on.
Notes
  • This idea would speed up development by enabling us to cycle through element selection without using the mouse.
  • When used in conjunction with the F2 idea, this would enable us to use Tab + F2 combinations to quickly cycle through elements and rename their labels and/or captions.
  • This idea could be extended to terminals on the block diagram. Suppose a terminal is selected on the block diagram, pressing tab would navigate to another terminal on the block diagram.
  • I'm aware that currently it is possible to use Tab or Shift+Tab to cycle between elements forwards or backwards when the VI is in Run Mode (Ctrl + M). While that is useful, this idea asks for more.
Thanks!
3 Comments
Petru_Tarabuta
Active Participant
P.S. Perhaps a more accurate idea title would be "Tabbing between front panel elements should be possible during Edit Mode".
wiebe@CARYA
Knight of NI
Traditionally, tabbing switches tool. It still does, if the auto tool is off.
But if auto tool is on, tab seems to be available... It just might work.
Petru_Tarabuta
Active Participant
Thanks for pointing that out. I never noticed that, perhaps because I have the auto tool selected 99.5% of the time.
