13 | |
7 | |
3 | |
3 | |
3 |
The last decade has seen a fantastic development in using neuronal networks to analyze data. Neuronal networks allow doing nowadays feasts that were unimaginable a decade ago at a tremendous speed. The latest release of LabVIEW allows using old TensorFlow versions <= 1.14. About four years ago, TensorFlow switched to TensorFlow 2.0, which resulted in a significant transformation in how models are organized. Models developed in TensorFlow <2.0 are incompatible with current standards. If National Instruments aims to maintain its position in the market of computer vision, developing tools to use current TensorFlow versions is a MUST.
