X.
The Options window should remember its location and size
Status: New
 which it is still not doing in LabVIEW 2015.
7 Comments
altenbach
Knight of NI
Is there an existing idea or other thread where this was ever suggested or discussed?
If so please link to it. Thanks!
(If not, how should NI know that this is what some users want?)
X.
Trusted Enthusiast
Trusted Enthusiast
I am saving space AND time by introducing the problem AND suggesting the solution in the same thread. It is borderline of a CAR suggestion though.
AristosQueue (NI)
NI Employee (retired)
No dialogs remember location. Modal dialogs are supposed, under both Mac and Windows standards, to come up centered on the active window. I don't think we'd change that just for this one dialog.
Remembering size would be fine.
X.
Trusted Enthusiast
Trusted Enthusiast
Let's make it non-modal too.
Darren
Proven Zealot
There are some dialogs that remember size and position. I wish they all would, modal or not. Kudos.
X.
Trusted Enthusiast
Trusted Enthusiast
Just to clarify why this is particularly important for the Options window: it is a large window and since the window doesn't also remember the position of the scrollbar in its different panels, each use of the options window requires scrolling and looking for the option you are interested in. Since we usually TRY different options before settling for one, this repetitive process is annoying.
Case in point: changing the default colors of the environment:
Before I close the window:
After I close it and reopen it:
So add this to the Suggestion: Let the different panels remember the scrollbar location
Manzolli
Active Participant
Looks like something simple to implement.
André Manzolli
Mechanical Engineer
Certified LabVIEW Developer - CLD
LabVIEW Champion
Curitiba - PR - Brazil
