| User | Kudos |
| 2 | |
| 1 | |
| 1 | |
| 1 | |
| 1 |
After placing a new graph, we might want to go to the plot properties dialog and change the color, label, etc. of the plots we want.
Bzzzt. No go! We can only edit plots that have been added in some other way. (by resizing the plot legend, wiring and running once with data representing several plots, etc.)
For comparison, have a look at the cursor tab. Here we can add and remove cursors at will.
My suggestion is to add the ability to add or remove plots on the plots tab properties page of graphs and charts.
It could look like in the image on the left.
