11 | |
8 | |
3 | |
3 | |
2 |
The key input of the Map Get / Replace Value node of an In Place Element structure is not a required input. This can lead to bugs, where a developer may have forgotten to wire the key. All other Map primitives require the key input.
The idea is to simply make the key a required input.
(The map isn't a required input either, but has a documented default. It should probably be required too though.)
Filed as bug 1105765.
