I sometimes use arrays of classic frameless colorboxes to quickly display a color table.
Unfortunately, the minimum size of these elements is 5 pixels :(, making a 256 element color ramp 1280+pixels wide, showing redundant information in 5 adacent pixel columns each. If we display the color ramp vertically, it would not even fully fit on a common 1080p display!
This makes it too wide to correctly display them in the forum and forces a size reduction that makes all other text and diagram code illegible.
(Yes, we can right-click...open image in new tab, and click the image to display it 1:1 (in chrome), but that's more work and not everybody knows that)
It would be perfectly OK if we could make these elements only 2 pixels wide (or high), making the array display a much more reasonable 512 pixels and keeping the front panel to a more reasonable size.
Idea summary:
The minimum size of the classic colorbox (frameless) should be 2x2 pixels (or even 1x1?) Currently it is 5x5, i.e. too big.
Already possible in LabVIEW today. See discussion thread for more details.
