The maximum and minimum values that correspond to the color ramp in 3D graphs should be configurable.
Currently the color map range autoscales to the range of the incoming data, but it would be convenient to be able to keep them fixed regardless of the graphs range of values.
Apparently this was possible in previous versions of LabVIEW (es. LabVIEW 6.1) using property nodes, but I have not been able to find an alternative way to do it in LabVIEW 2009 and later.
