JasonD_at_UML
Thin Cluster, Thin Array borders
Status: New
Hi, I do a lot of UI work with LabVIEW, and I'm finding over and over that when you have an array of clusters, the appearance is still to "fat".
I'd like to see a very thin border for Arrays and Clusters.
If you look at the "Simple String" control, this is exactly what I mean. It's a single pixel border.
Maybe like this:
13 Comments
Broken_Arrow
Active Participant
As far as the GAP between elements, see idea here.
Richard
MichaelAivaliotis
Active Participant
If you want a borderless cluster, you can get it from this LAVA thread: https://lavag.org/topic/11002-cluster-border-thickness/
Michael Aivaliotis
VI Shots LLC
AristosQueue (NI)
NI Employee (retired)
Michael posted a link to the topic overall... the files you actually want are here:
https://lavag.org/topic/11002-cluster-border-thickness/?p=65950
In LV 2009, the zero border version doesn't appear to work -- someone put in some sanity check code and autofixes "bad" clusters, so my hack doesn't work. But the 1-pixel version works fine. It is much thinner than what ships with LV today.
