6 | |
6 | |
3 | |
2 | |
2 |
While in most cases it is possible to write a code with built-in timeouts, but there are cases when you do not have means to do that, so It would be nice to be able to specify how much time would you like to let particular VI (function) to have for execution.
Attached example has 1ms resolution and forced to use VI server calls to pass data to and from VI to make it work with STOP command.
Natively it can be done with much tighter resolution (us, or better) and without server calls.
P.S. Sorry for just PNG but Snippet for this VI was not capturing code correctly, Boolean property node end up losing its link...
