6 | |
6 | |
3 | |
2 | |
2 |
Simple Idea:
There should be a timed FOR loop.
All the same awesomeness of the Timed (While) Loop, but stops when the auto-indexed array finishs or after N executions.
A picture because Ideas with pictures get more Kudos:
Any idea that has received less than 7 kudos within 7 years after posting will be automatically declined.
