2 | |
2 | |
2 | |
2 | |
1 |
One thing I love with LabVIEW is to be able to execute the same source code on multiple targets (Win, Linux, NI Linux RT, etc)
I use Linux more and more to deploy my LabVIEW built apps and now instead of VM I use Windows Subsystem for Linux (WSL) on Windows 11, in very few steps I can create an Ubuntu instance, add a desktop and xrdp and then remote desktop into it.
What would be fantastic is to not event need a desktop and xrdp but just install LabVIEW in the WSL instance via terminal and then run LabVIEW on Windows and select the WSL instance as execution target as I would do for an RT target.
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
