10 | |
3 | |
2 | |
2 | |
2 |
Customized booleans with independent sizes and bounding rectangles for each of their four button states would open a number of possibilities, some cosmetic some funcional, for FPs. For one use case, see this thread. Presently they can sort of be created (Customize control/Operate/Change to Customize Mode/independent sizes etc.) but the resulting dimensions and the relative placement of the elements in the various states are absolutely unstable (possibly internally undefined?), making the technique borderline usable.
