Typedef'd clusters are excellent for managing linkages between, but poorly accomodate GUI arrangements. I find myself constantly unbundeling cluster components simply to achieve a reasonable GUI. This results in multi-part points of maintenance that should not be necessary.
I am constantly unbundling cluster components just to do this. this results in all kinds of consequences like having to remember where every GUI that uses the control is for modification, forcing multiple events in event structures to handle what ultimately is an event for a singular cluster. Lets Decouple the GUI from the typedef and allow for unbounded elements that don't move when adding cluster components. Simply place any new elements at the origin and let me decide where they belong.
