When you create and register user events, you need to send a copy of the event ref to the Event structure to be able to use and generate events. Why? We should be able to extract/unbundle the registered events. On the same thoughts, unregister should also return the ref so it can be destroyed, similar to how Open/Close File ref works.
TLDR; We should be able to extract and use registered event refs, e.g. through unbundle.
/Y
National Instruments will not be implementing this idea. See the idea discussion thread for more information.
