elset191
Undo Tile (ctrl + T)
Status: Already Implemented
Fixed in LabVIEW 2009 and later
I spend time making the size of my front panel and block diagrams fit my code well.  Unfortunately everyone once in a while I will hit ctrl+T when I'm trying to press ctrl+R to run my code, and it of course changes the dimensions of my windows.  I try to undo the operation, but it does not work properly (or as I would want it to).  It moves it back to its position, but the dimensions are all wrong still.  Very frustrating.
I propose that Undo reverts the panels to their pre-tiling size.
Tim Elsey
Certified LabVIEW Architect
19 Comments
elset191
Active Participant
Altenbach, I've never used it intentionally.  I just miss sometimes with ctrl+R.  And I have also run into clicking terminals on xcontrols (And regular VI's too) which is really annoying.
Tim Elsey
RavensFan
Knight of NI
That's why I don't have the problem.  I never use Ctrl-R.  I always click on the Run button.
Take a look at Smercurio's suggestion in this thread http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Remove-Window-Tile-Feature/idc-p/970272#C1828 on how to disconnect the Ctrl-T shortcut from the Window Tile function.
I don't see a reason to get rid of Ctrl-T considering there is a way to disable it.  That said, I really can't see a use for it and wouldn't miss it either.
PaulG.
Active Participant
CTRL-Z will undo the CTRL-T properly in LV2010 beta. I just tried it.
PaulG.
Retired
JackDunaway
Trusted Enthusiast
PaulG, I'll get on to you before tst (he's caught me talking about Beta before!), but the Beta should not be discussed publicly.
tst
Knight of NI Knight of NI
Knight of NI
Actually, in this case, it's less of a problem, because it's just a matter of saying that a bug was fixed (and also because it was already fixed in 2009. Sorry, Paul, I didn't notice that when I posted the link).
___________________
Try to take over the world!
muks
Proven Zealot
Please remember that no discussion of the beta is permitted outside of the private forum set aside for that purpose.
Robert McManamy
LabVIEW Platform Beta Coordinator
Just pasting the message which i got today......ironically?
தமிழ்நேரம்
UNDO the ctrl+T will be fine for me.
அன்புடன்
தமிழ் நேரம்
முதல் இந்திய ஆய்வுமெகபொப சிற்பி
சோதனைநிறுத்தம் சிற்பி
மற்ற சான்றிதழ்கள்
யாதும் ஊரே! யாவரும் கேளிர்!!
ajmayer
THE SHORTCUT CAN BE REMOVED IN OPTIONS.
It's one of the essentials during configuration like turning off automatic tool and automatic error reporting
Darren
Proven Zealot
Status changed to: Already Implemented
