 Mads
			 on
		05-03-2016
		02:11 AM
			4 Comments (4 New)
			Mads
			 on
		05-03-2016
		02:11 AM
			4 Comments (4 New)
		Make it easier to find the right product in the uninstaller
If you install a lot of National Instruments developer tools the uninstaller becomes very crowded. You can have 50-100 components, often with similar names and varying name structure. Finding the component you want to uninstall/modify/repair can be difficult.
The fact that things a split into so many separate components is practical, but the components should be organized better:
They could be:
Allow us to specify a new source location
If I want to repair or modify an installation it might turn out that the original source for the installation is gone, or I have a new (identical/compatible) source that I would like to use instead. It would be nice if the uninstaller handled this, instead of insisting on the original.
