It would be nice if in the UTF-Test Cases window the splitter between inputs and outputs could be replaced with a "Horizontal Splitter Bar" in order to allow to customize the visible part on either pane.
As you can see my inputs are far more than the outputs so it would be nice to see them all at once...
