Several times I have found an example that pertains EXACTLY to the subject that I am interested but I am unable to open the VI due to licensing. My suggestion is to 'unlock' the example finder by letting the developer to see a screenshot of the block diagram/front panel. This would maintain the licensing but would also allow everyone to see (but not use) the techniques used in the 'forbidden' example.
