| User | Kudos |
| 4 | |
| 3 | |
| 3 | |
| 3 | |
| 2 |
This idea will probably have a narrow audience... those of us who use the "zip" functions in LabVIEW. There is currently an unzip function that takes a zip file on disk, then writes the unzipped files back to disk. To manipulate zipped files, you must then access the disk and load into memory. In other words, 3 disk operations... read zip, write file, read file.
There needs to be a function that unzips the files into memory, with the output of this function as an array of flattened strings, byte arrays, or data pointers.
Any idea that has received less than 8 kudos within 8 years after posting will be automatically declined.
