I've had a look around and can't see anything in here like this already (which surprises me so I'm suspicious that it's just the search algorithm failing) but I'd like to see options in the LabVIEW Project tree for changing target hardware.
For example, I have a development underway using a cRIO-9114 chassis with a 9024 controller, and a 9144 EtherCAT expansion chassis. The primary chassis is about to be upgraded to a 9116, as we need a bigger FPGA, and although the hardware upgrade process is straightforward, upgrading the chassis in the LabVIEW Project is not a possibility. Instread, I need to create a whole new target, and copy and paste every VI, node, FIFO, DMA etc. across. There's quite the possibility that I'll miss something, or the new target won't have all the same settings (Scan Mode period and priority settings for example), leaving me with that niggling feeling that something under the hood will be wrong. It would be much neater if this was an automated migration.
Furthermore, as the hardware is not here yet, I need to create the new target and all it's modules manually, which will take me quite some time. An automated migration would save me that trouble.
Duplicate of https://forums.ni.com/t5/LabVIEW-Real-Time-Idea-Exchange/Modify-Hardware-Model-in-LabVIEW-Project-Wi...
