4 | |
4 | |
3 | |
3 | |
3 |
It would be nice if you could change a selected font style by using the standard windows (MS office) shortcuts, such as CTRL-B for bold and CTRL-U for underline. This would save many mouse clicks.
I realize that many people don't use Windows, so maybe it could be customized in the .ini file or would be dependent on what OS your are running.
Available in LabVIEW 2018 and later. The Ctrl-B, Ctrl-I, and Ctrl-U shortcuts now bold, italicize, and underline text, respectively. This behavior only occurs while a text field is being edited. Otherwise, these keyboard shortcuts maintain their normal behavior.
