PrimaryKey
Usefull information in Network Streams URL Property Node
Status: Declined
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
when you use the URL property node for network streams you allways get localhost url only.
The Idea is simple. Just to change the information provided by this URL not for localhost but for the other endpoint of the connection. This would simplify managing multiple stream connections.
Piotr Kruczkowski
Certified TestStand Architect
Certified LabVIEW Architect
1 Comment
Darren
Proven Zealot
Status changed to: Declined
