11 | |
7 | |
3 | |
3 | |
2 |
Right-clicking on a case structure, we still have the option to convert a case structure to a stacked sequence.
I would prefer if this option would disappear without a trace forever :D. It has no purpose in life!
Nobody should ever use that option! It makes no sense!!! 😄
(I would probably retain the option to convert a stacked sequence to a case structure)
