5 | |
2 | |
2 | |
1 | |
1 |
Good day forum
The already VI hierarchy is already a very useful tool in tracing dependencies and all, but if we can tweak it in the right way, it may be able to serve other purposes for instance, a organization chart plotter or mind mapper by playing with vi-subvi relations (multi-connection), icons as glyph, floating nodes as control/indicator terminal subVIs, etc.
if only this feature can be developed for LV users, it can serve as an additional value-adding tool, especially for mind mapping. should this be picked up, I would very much like to see a "resize-able" glyph for starters 🙂
or if it is remotely possible with the current versions through VI scripting, maybe the community can collaborate and work something out? and put it into Tools Network.
