With the increasing size of the LabVIEW ecosystem, there is a growing number of third party tools written in LabVIEW that are versioned independently from LabVIEW's version number. For example, I could create an API that has versions 1.0, 2.0, and 3.0, and all three versions could be compatible with LabVIEW 2009 or later. Tools like VI Package Manager make it easy for content creators to publish multiple versions of an API, and for users to upgrade and downgrade between those versions. However, this ease of use disappears if significant changes have been made to the VIs in an API, such as:
If any of the above changes are made to VIs in an API between versions, it can become impossible to migrate code between the two versions without a lot of manual searching, replacing, and relinking.
LabVIEW should provide a mechanism to define mappings between old and new versions of third party toolkit VIs. Consider the case where I make the following changes to a VI from my toolkit:
 Version 1.0  |
 Version 2.0  |
 VI Path
 <userlib>\mytoolkit\CompRes.vi  |
 <vilib>\mytoolkit\Compute Result.vi  |
 Owning Library
 none  |
 Mytoolkit.lvlib  |
 Connector Pane  |
I should be able to create a mapping file included with version 2.0 of the toolkit that describes the changes made between versions 1.0 and 2.0 of the VI. This way someone could write an application that calls version 1.0 of the VI, then upgrade their toolkit to version 2.0, and the application source code would be able to find, load, and relink version 2.0 of the VI without any hassle.
