8 | |
6 | |
4 | |
3 | |
2 |
If one wants to prevent execution of a VI when there is an incoming error, it has to put case structure on the block diagram.
It would be easier to have a property that prevents execution of the VI if there is an incoming error. This property could be set in VI properties or in shortcut menu.
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
