13 | |
11 | |
3 | |
3 | |
3 |
Our industry could use a function to export a VI as a text file, similar to how we can export a UIR file in LabWindows/CVI. We are only allowed to move certain file types off of the system, and .VI will never be one of them. The functionality (ie the nodes, parameters, and connections between the nodes) would be the biggest concern of the block diagram and not so much as the physical layout, and a second file could be used for the layout of the front panel. This would also allow us to perform a Diff between two versions of a VI using a 3rd party comparison tool.
Declined for reasons listed in AristosQueue's reply.
