| User | Kudos |
| 4 | |
| 3 | |
| 3 | |
| 2 | |
| 2 |
I, like many others I am sure, have multiple LV versions installed on my computer.
I have often wished for a small launcher program (linked into Explorer.exe under Windows) which has a peek to see what version a VI (or ctl or whatever) is BEFORE calling the respective LV version.
It could also have an option to show a dialog whenever a VI is double clicked in a version different to a version of LV which is ALREADY open asking if it should be opened in the native version or in the currently opened version.
An alternative would be to treat VIs opened from a different version as locked (read-only), forcing either a manual setting of write permissions or saving under a different name.
Shane.
